20-05-2017 #11
Right, finally a proper bit of machining to show... I did a small re-design on the face plates as they still weren't quite going to fit on my machine and I wanted a slightly wider stance. In order to keep the structural part as a single piece, I made the main piece slightly shorter and then added removable "wings" for the extension.
I've left the wings uncoloured to make them easier to see:
Made the front main face plate today:
Started with a jig plate made from SRBP - nothing fancy, just a plate I could machine flat and put some screw threads into, and a slab of 20mm eco-cast plate.
After interior roughing, contouring and drilling ops:
I drilled though the m8 screw holes with a 6.8mm into the jig plate and tapped them to allow me to then fix the plate down through those, which then allowed me to the remove the clamps and run the exterior ops:
Top side finished:
Then flipped it over and re-fastened to run the rear chamfer:
And done:
The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
