    very nice indeed!
  2. The Following User Says Thank You to charlieuk For This Useful Post:
  3. #2
    No news on the CNC front, apart from that I've just ordered a big fat stack of aluminium, which is enough to do pretty much all of the remaining parts (just the spindle mount and the extrusion for the gantry missing). Hopefully that'll arrive sometime towards the end of the week.
    However I haven't been totally idle, I have just installed my newest toy which is going to be a bit of a distraction! I haven't used a lathe in many moons, probably not since I was 16 at school, and I have pretty much no idea what I'm doing so it's going to take a bit of time to learn it all. Intentions are to get to grips with using it manually then think about a conversion to CNC.
    Wabeco D4000 with DRO's:
    Playing with some test scrap:
    Mmmmm... complicated....
    Anyway, hope to have the aluminium by the end of the week and apart from finishing off the BBQ project, carrying on the new router is top of my list so should see some progress soon.
  4. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  5. #3
    Lathe looks really nice, well done. Colour scheme matches your decor !
    I was in the same place as you - hadn't used one since school and had plans for a CNC conversion. But I've been running the lathe for a while now, and made some nice parts, and most operations are pretty intuitive and you can get up to speed with the general stuff quickly. DROs are so handy, I have a colleague who still uses the dials on his lathe and is happy, but I couldn't go back to that system now.
    So what I would say is use it for a while before thinking about CNC. I've found that it is pretty quick to make the parts 'by hand' if they are one-offs, and for me at least the CNC conversion idea is now on hold. If I do ever go CNC then I'd look to keep the handles in similar places as MPGs and have the easy option of semi auto operation.
  6. #4
    Could this end machine ballscrews?
  7. #5
    routercnc - Haha yeah it does go rather nicely doesn't it! Happy accident!
    Yeah it has occurred to me that certain jobs are much quicker and easier to do manually, but I think threading and complex shapes like balls/curves are certainly going to be easier on a cnc'd version, especially for someone of questionable skill such as myself... Ideally I would be able to use it both manually and automatically, which I suppose should be possible with a nice pendant. Definitely intend to use it manually for the foreseeable though so we shall see how things go.
    Desertboy - In theory, the bore is 20mm so it can certainly physically accept a 16mm ball screw for machining. I believe machining them is a bit of an art though. Probably somewhat depends on the screw and how hardened it is. I think everything I have seen suggests that you need to grind off the case hardening before trying to end machine them.
  8. #6
    So been a bit busy with work, but this afternoon I had a bit of a play with the lathe.
    Trying to make some nice snug shoulder screws for the alignment of the X-Axis mounting plate. I've just been getting the hang of it all really so only made the one so far.... Think I need a slitting saw to make the slot on the top.
    I've tried both brass and stainless steel. Brass is certainly easier to work, but not sure what to go with.
    Test fit:
    Figured out this threading thing... seems it would be much easier to do this sort of operation if it was CNC'd up. The change gears are a bit of a faff.
    Fits nicely:
  9. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
  10. #7
    Good looking machine and nice work with the machining. It's handy to have another cnc that can do the machining, I had do all my stuff by hand and using templates sometimes.
  11. #8
    Hi
    I know stainless can be a pain to machine but i would still use it in your application, think there would be a problem with brass in ally(electrolosis) if its exposed to moisture.
    How are you cutting the thread ? i use single point tool (easy to grind) and set the topslide over to half the included angle so you only cut on one flank.
    Machine looks great
    Regards
    Mike
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
