Damn, that's some very nice work there.
03-09-2017 #2
Sorry to hear about your troubles in post 170. Annoying when the part is big like that and expensive to replace.
Drill guide templates are very handy to make sure the holes are precisely where you want them. Got some more to do in my build later on.
When you flip the ball nuts have you got some metal tubing to roll them onto to keep the balls in place? If not I can measure the tube I use so you can turn something down.
Good work - keep it upLast edited by routercnc; 03-09-2017 at 06:13 PM.
03-09-2017 #3
Cheers desert.
Yeah very annoying, but could have been worse I suppose...
They came with some plastic tubes actually, but thanks. Of course I tried to use the Z-axis 1604 ball screw's tube for the 1605 and the end result is that tonight I learned how to re-pack a ball nut lol. Thankfully I did it all in a sandwich bag so no balls were lost. Helps when you use the right tubeWhen you flip the ball nuts have you got some metal tubing to roll them onto to keep the balls in place? If not I can measure the tube I use so you can turn something down.
Other than that I made the required design tweaks and modified the plate... I wanted to give the cutout that clears the motor mount a little more clearance and I also made room for the flipped nut.
Aligned the plate using dowels to make sure it was square to the axis, then used a probe to determine zero... occurred to me that perhaps not many have seen the touch probing screen on mach4, quite convenient to use for most circumstances:
modifications made:
Fitted to the machine, for ballscrew alignment the plan is to assemble by the fixed position motor mount here:
Then drive it up to the top with the floating bearing mount screws loosened off, then re-tighten once up there... ensures the screw is lined up to the linear rail at both ends. So far seems to have worked as it's nice and smooth at both ends with no binding.
Now I just need to make the other side
The Following User Says Thank You to Zeeflyboy For This Useful Post:
04-09-2017 #4
Looking good.
04-09-2017 #5
The Following User Says Thank You to Nickhofen For This Useful Post:
08-09-2017 #6
ta!
So nothing exciting, bit of a wash rinse repeat but in mirror image:
And now got both fitted... next up will be the Z-axis I think.
I also thought I'd just put this little video of my current machine munching some aluminium... I think she does a pretty good job for a 6040 type machine. This particular bit I did with a 6mm x 22mm single flute end mill with 2000mm/min, 1.5mm axial engagement and 5mm depth of cut at I believe 19k rpm.
The Following 3 Users Say Thank You to Zeeflyboy For This Useful Post:
08-09-2017 #7
Hi Zeeflyboy,
Very nice speeds for a small router. I only use about 400mm/min with an 8mm endmill and 0.5 radial cut on my milling machine, so I am rather jealous. I'm starting the process of building a router similar to your new one, but with dual screws/pulley on the X instead of your two motors, so I am following your progress.
One thing I noticed, although your finish looks very good, in the area circled in red you have these vertical lines that are kind of similar to what I sometimes get with my milling similar plate thickness. Do you know what it is causing it?
Edward
08-09-2017 #8
Good work. It machines aluminium nicely all things considered.
The plates you have just made- any reason they were not a single plate instead of 2 separate plates? I can't remember what the upper structure was going to be but I'm sure it would have benefited from this extra stiffness.
Initial design advise wanted
By driftspin in forum Gantry/Router Machines & BuildingReplies: 45Last Post: 24-10-2017, 06:55 PM -
Initial Design Check Please
By Gotty101 in forum Gantry/Router Machines & BuildingReplies: 90Last Post: 28-02-2017, 07:53 PM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
