  1. #10
    Really odd - I've been using imgur for all the photos so nothing has changed... I really can't think why it only affects you, and only for recent pics... how odd.
    RouterCNC - I just printed one out which I enlarged the cut out by 0.15mm on and I think it's perfect. Given you are using 20mm rail too you are welcome to have my model to modify as needed to make the exterior fit your machine? You use fusion right?
    If you need them printed out I can print them out and pop em in the post for you too if that helps. Flexibles can be a tricky thing to get right, some printers cope better than others (bowden types really don't tend to do great for example) and stuff like cheetah is pretty expensive to buy if he doesn't already have something comparable.
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
