  1. #9
    Thanks chaps.
    Alex - the attwater SRBP msds seems pretty benign.. I would be surprised if it was any worse than MDF for you anyway! http://www.attwater.com/downloads/sr...lth-safety.pdf
    I think as with all these things it's best to avoid inhaling any dust anyway.
    Made the front plate today, bit more of a challenge to hold down as it doesn't have sufficient through holes... instead I had to spilt the operations up a bit.
    First setup - machined the ends and the back side for rail mounting holes, HD16 mounting pattern and some temporary alignment block holes to make sure the first rail is straight to the edge of the plate.
    Then re-clamped and ran the side machining:
    Drilled a few 6mm dowel pin holes to butt the piece up to when flipping for top side operations:
    Unfortunately I don't have any correctly sized m5 bolts for mounting the rails. Amazing - seems no matter how many screws I have on hand, I never have enough of the correct size!
  2. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
There are currently 46 users browsing this thread. (0 members and 46 guests)
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
