12-02-2017 #6
If you're driving a single servo (I don't know the interface to these, but I'm going off your post) - and the drive is +/-10v wrt a common ground, then you need only one non-inverting amplifier.
Capacitors - pick a couple of 100nF ceramic capacitors and locate them close to the op-amp, between positive&ground, and between negative&ground.
Regarding which op-amp - how quickly will the signal change?, the one you originally picked had, I think, a gain/bandwidth product of a pretty miserly 75kHz, but if the signal is just driving an axis then I that'd be absolutely fine. If it was driving a spindle then it should still okay given the low gain you're looking at.
Easy Servo Drive?
By Tenson in forum General DiscussionReplies: 38Last Post: 19-10-2015, 04:39 PM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
FOR SALE: 160v dc servo drive
By dazza in forum Items For SaleReplies: 0Last Post: 27-01-2015, 03:16 PM -
Servo drive problems
By Tomnewry in forum Motor Drivers & ControllersReplies: 15Last Post: 27-03-2013, 11:30 PM -
UHU Servo Controller
By gbar in forum Stepper & Servo MotorsReplies: 4Last Post: 11-05-2012, 12:12 PM
