Thread: PWM Settings
15-02-2017 #11
Correct. BTW Gerry I was told on Mach3 there is the "Calibrate Spindle" on the Functions Config menu. Is this any good for me to calibrate my spindle?
15-02-2017 #12
You need an encoder on the spindle to calibrate it.
What kind of VFD do you have? You may be able to adjust the frequency to the voltage so that you get the correct RPM.Last edited by Ger21; 15-02-2017 at 05:19 PM.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
15-02-2017 #13
15-02-2017 #14
Calibrate spindle will do nothing, and if you try it, it make it worse
Gerry
15-02-2017 #15
15-02-2017 #16
I also found these
10mF 50VMP, IEC NP 4.7MFD 50V, IEC NP 16MFD 50V
15-02-2017 #17
No, the Gecko output is already filtered so you do not need capacitors of any value. Looks like the output voltage of the Gecko is about right anyway for the speeds demanded so looks more like a VFD issue. My HY VFD works fine with reasonable linearity so maybe there are some other parameters that can affect this?
15-02-2017 #18
Thanks Neale, I will check my VFD parameters again
Nicolas
15-02-2017 #19
Hey Neale, if you have Mach3 with your VFD can you tell me what parameters you have on the Motor Tuning page for the spindle? I have: Stepsper=1, Velocity=120, Accel=4, Steppulse=2. Dirpulse=2. Some say these settings have no effect on PWM and some say the same but suggesting the Accel/Velocity should be about in the middle of the scale for each
16-02-2017 #20
As I understand it, the g540 is basically just a breakout board and four stepper drivers in a single box. Mach3 does all the real work. I am using a CS Labs CSMIO-IP/M where a lot of the processing is off-loaded from Mach3 to the motion controller. Things like spindle control are also handled partly by Mach3 and part by the IP/M which has its own configuration parameters so I'm not sure that any of my system's settings would be relevant and might be misleading. All I can say is that the IP/M and the HY inverter do seem to play well together but I did have to follow the various manuals very carefully to get it all set up. The only thing I forgot to do was change the motor pole parameter in the VFD as the front panel display currently reads half the demanded speed but that's a trivial problem. In your case, there is a non-linearity between input voltage to VFD and VFD speed/frequency which is more puzzling.
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Saving machine settings between sessions
By Neale in forum Machine Control SoftwareReplies: 19Last Post: 07-05-2014, 08:17 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM -
Calculating torque settings for bolts.
By swarf-boy in forum Machine DiscussionReplies: 2Last Post: 22-12-2010, 12:18 AM
