Thread: PWM Settings
As I understand it, the g540 is basically just a breakout board and four stepper drivers in a single box. Mach3 does all the real work. I am using a CS Labs CSMIO-IP/M where a lot of the processing is off-loaded from Mach3 to the motion controller. Things like spindle control are also handled partly by Mach3 and part by the IP/M which has its own configuration parameters so I'm not sure that any of my system's settings would be relevant and might be misleading. All I can say is that the IP/M and the HY inverter do seem to play well together but I did have to follow the various manuals very carefully to get it all set up. The only thing I forgot to do was change the motor pole parameter in the VFD as the front panel display currently reads half the demanded speed but that's a trivial problem. In your case, there is a non-linearity between input voltage to VFD and VFD speed/frequency which is more puzzling.
16-02-2017 #2
Thanks for your time Neale, much appreciated
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Saving machine settings between sessions
By Neale in forum Machine Control SoftwareReplies: 19Last Post: 07-05-2014, 08:17 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM -
Calculating torque settings for bolts.
By swarf-boy in forum Machine DiscussionReplies: 2Last Post: 22-12-2010, 12:18 AM
