  1. For members amusement some details and images of my newly (today) commissioned MK-2 CNC machine.
    Details:
    • Primary use: hardwood v-carving and associated 2D cutting.
    • Effective working area: 800 x 500mm
    • Designed max velocity: 1,800mm/min (typical v-carving 600-800mm/min)
    • Removable raised MDF base to accommodate deeper work objects.
    Main components:
    • 80mm aluminium extrusion gantry (KJN) on 40mm steel frame (local stockist)
    • Electrics: 4 Nema 23 motors (X-axis x 2) with 542 drivers and two 42v PSU (Zapp)
    • Rail: X- & Y-axis 20mm supported (Zapp); Z-axis 20mm unsupported
    • Ballscrew and bearings: 1605 (ebay Linearmotionbearing and smpart)
    • MACH3
    • {Very large floor mounted E-stop switch (a 'piece of cake' to install)}
    To do:
    • Fit limit switches
    • Install dust extraction - dust shoe design.
    • Select and fit water-cooled spindle.
    • Modify to MK-2.1 - create larger working area - transfer X-axis components to Y-axis and puchase additional extrusion, supported rail and ballscrew for X-axis. Hopefully a quick win.
    *** A gold star awarded for identifying which forum member's design this machine was based on.
    And next - steel frame already constructed for MK-3 machine - sized for working 8' x 4' board.
    Don't be too harsh - it's a hobby.
    Karl
ID:	5790   Click image for larger version.
ID:	5789   Click image for larger version.
ID:	5788   Click image for larger version.
ID:	5787   Click image for larger version.
    Having bought 80mm extrusion, combined with not having a tall gantry you have the potential for a very strong machine.
    I notice you have chosen TBR rails over SBR, which is good since they are stronger yet significantly more expensive as you can't get them from China (eBay seller linearmotionbearings2008). Using supported rails on the Z-axis and swapping the rails round such that the rails are mounted to the Z-axis would make the Z-axis significantly stronger since the overhang is reduced.
    Minor point as it's probably only temporary anyway - I'd solder the motor wires since if one pulls out of the terminal blocks whilst powered there's a good chance the stepper driver will be broken.
    Still, for V-carving you'll be fine.
  3. Quote Originally Posted by Jonathan View Post
    I notice you have chosen TBR rails over SBR, which is good since they are stronger yet significantly more expensive as you can't get them from China.
    Many thanks. This is where I admit to not knowing the difference between TBR and SBR rail: I just bought some rail. What's the difference?
    Karl
    Quote Originally Posted by Karl View Post
    The aluminium support for the TBR rails is stronger than on the SBR rail, and the bearing blocks for TBR are bigger and flanged, which spreads the load again making them stronger.
    Compare the pictures here:
    http://www.zappautomation.co.uk/line...g-c-24_93.html
    I would still but the SBR rails from linearmotionbearings2008 on eBay because the price difference means you can afford a much bigger rail which is clearly stronger:
    http://www.ebay.co.uk/itm/2-linear-b...#ht_729wt_1087
  5. The Following User Says Thank You to Jonathan For This Useful Post:
  6. Looks great, is there any issue with using sbr / tbr rails on their side - particularly on X and Y axis - cantilevering off them rather than bearing straight down?
  7. #6
    Quote Originally Posted by JoeHarris View Post
    Yes - the load rating of the bearing blocks varies depending on the direction of the applied force. In other words if the force is in the direction attempting to pull the bearing off the rail clearly the deflection will be greater. For that reason it's best to mount them so the rail supports are facing each other. This evens out the deflection, so you effectively have medium deflection all round instead of large deflection when cutting one way and small deflection the other way.
  8. Quote Originally Posted by Jonathan View Post
    I don't understand that - not saying you're wrong just that I don't understand. That said, we of course accept that bearings are not operating at their best when they're being pulled off the rail.
    Mounting the rails and thereby bearings (on which the z-assembly moves along the y-gantry) top and bottom - with the bottom rail inverted - means (by my understanding) that the load is primarily carried by the top 2 (typically) bearings; the bottom 2 bearings preventing rotation of the z-axis assembly. With the rails/bearings mounted on their side the z-axis load is (again by my way of thinking) carried by all 4 bearings albeit with the force on the side of the bearing. So load-wise is 4 bearings carrying the weight on their side better or worse than 2 carrying the weight conventionally?
    With regard to deflection (or moments), when the y-axis gantry moves in the x-direction, I rather assumed that where one pair of z-assembly bearings were effectively being pulled off the rail (tension) the other 2 would be under compression and vice-versa with direction of x+/x- travel.
    This is interesting because I was planning to use the same design for my next larger (8' x 4') machine. I found this design (which I borrowed from another forum member's post) to create a low-profile y-gantry with easy mounting of rails and y-axis motor/ballscrew.
    Now I'll have to get the pencil, paper and abacus out to calculate some moments; unless someone has an 'app' for that.
    PS. Obviously, I accept the rails-on-their-side design must be wrong since most implementations don't use it - I still think it's quite a neat design though.
    Karl
  9. #8
    Hi Karl,
    I think the design you have posted with rails their side would still work OK, especially for hobby use. But to elaborate a bit further . . .
    Considering the forces - there are 2 forces acting on the bearings, one from the mass of the bits they are carrying (router, motors etc.), and one from the cutting forces. I've ignored the forces due to accelerations because some early calcs showed these to be small, especially on a hobby machine.
    The mass of the bits is huge compared to the cutting forces (especially wood) so I would orient the bearings to take this larger load. In this case I would favour Jonathan's arrangement, top and bottom.
    In comparing 4 bearings on their side with 2 bearings on top (and 2 guide bearings on bottom), I would agree that the top/bottom arrangement puts more load on the top 2 bearings vs spreading it over the 4 side bearings, but I wouldn't worry about exceeding the load rating because you are probably still miles away. Instead consider what happens to that load when it is applied to the stiffness of the bearing in that direction. Arranged on their side the large mass of the Z axis is trying to open up the bearings, thereby slightly reducing their preload or grip on the rail. This would be like having very slightly smaller ball bearings inside the unit which would slightly reduce the accuracy of the carraige on the rail. Arranged on top and bottom you are mainly loading the bearing in the stiffest direction, so would expect that to give the best overall results even though it is carrying more load per bearing.
  10. Yep. I can relate to the argument that having the bearings on their side would tend for the load to open them up. I never considered that but obvious when one thinks about it. Oh well, we won't be using the bearings-on-their-side design for the next machine then.
    Karl
  11. Ref discussion in thread above. Is this bearings on their side I see in this commercial machine?
  1. BUILD LOG: This is my first BUILD please help.
    By DigiSoft in forum DIY Router Build Logs
    Last Post: 27-01-2016, 04:37 PM
  2. Add-on CNC build log
    By bikepete in forum Milling Machines, Builds & Conversions
    Last Post: 06-02-2013, 03:02 PM
  3. Build or buy?
    By jonnydeen in forum Machine Discussion
    Last Post: 13-05-2012, 11:01 PM
  4. Just a tip for anyone looking to build CNC
    By GeorgeD in forum Gantry/Router Machines & Building
    Last Post: 12-07-2010, 06:08 PM
  5. BUILD LOG: my build
    By jonm in forum DIY Router Build Logs
    Last Post: 22-04-2010, 10:14 PM
