18-04-2017 #101
The Following 3 Users Say Thank You to Boyan Silyavski For This Useful Post:
20-04-2017 #102
Any recommendations on bits for fillets?
Like a round over tool for routers.
Also looking for alternatives to something like the Haimer Universal 3D Sensor.
Was looking at Zeeflyboy's link to the TPA2 but need something soonish and cheaper :pLast edited by JOGARA; 20-04-2017 at 01:13 PM.
21-04-2017 #103
Does this look about right for this 3 flute roughing bit?
https://www.shop-apt.co.uk/economy-3...-diameter.html
I have a feeling that 3000mm/s is too much. Gwizard is saying 1000mm/s.Last edited by JOGARA; 21-04-2017 at 01:19 PM.
21-04-2017 #104
1000/S ? Do you mean 1000mm/min
21-04-2017 #105
Doh
Of course :p
Also, not 100% on the 1mm and 2mm. Wanted the single flutes but having to wait. Might as well try these.Last edited by JOGARA; 21-04-2017 at 02:01 PM.
24-04-2017 #106
Really struggling with the feeds and speeds for this 3 flute roughing bit.
Works fine for a few seconds then starts to chatter.
Guessing it is also a cooling problem?
Got the mister blowing a lot of air on it, also tried with a bit of water but same problem.
25-04-2017 #107
I have gummed up the roughing bits on more than one occasion when milling ecocast plate... to the extent that I actually had to dissolve the aluminium to get it off the cutters. What feeds/speeds and DoC/step over have you been trying?
Like I said they are definitely far more sensitive to incorrect speeds and feeds than single or 2 flute, proper coolant/lubrication would widen your envelope significantly.
25-04-2017 #108
25-04-2017 #109
removed......
25-04-2017 #110
So it looks like heavy mist/flood works really well.
The finish quality is really good too.
Having some odd problem where the Gcode is saying helical down, but Mach3 isn't doing it. It is still running the rest of the code as it should be but ignores Z.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
