26-02-2018 #9
Not sure if it's the same problem, but something like this happens with the CSMIO motion controllers when you do a tool-change invoiving a touch-off operation - it just gets confused. Fortunately, the answer in that case is to "upgrade" to a slightly earlier version of Mach3. I'm now running .028 (from memory) and that works absolutely fine. M6 tool-changes with touch-off tool setting aren't a problem.
Not sure if you are seeing the same or closely-related problem, but might be worth looking at. Life is easier if you don't have to switch files!
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
