11-03-2018 #10
Not necessarily.? Mach3 by default will let you Jog away between tool changes then when cycle start then go to next operation.
However, when using external controller some functions are taken away from M3 and handled by the controller and I'm pretty sure Jogging is one of them.
So if the controller doesn't handle this correctly when it hands control back to mach3 things can get screwed up.
This why Neale was seeing an issue when probing with Cslabs controller. In Cslabs case it's actually certain versions of Mach3 which changed how they worked at fault not the controller. Works fine with some not with others.
I think this could be the case here. I don't know which controller your using but might be worth trying few different versions of Mach3. I find older versions to be more stable, like neale I use 0.28.Last edited by JAZZCNC; 11-03-2018 at 06:38 PM.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
