Thanks for all the info.
Looking at the steppers on Zapp, http://www.zappautomation.co.uk/elec...ription_tabbed
These ones are (what I believe) you are talking about?
Parallel with 3.2 inductance and 3Nm holding torque at 4.2A.
Can I ask what power solution you are using to get 68v?
I took a look at those controllers but they are way out of my price range.
Currently the steppers and drivers are costing me £300.
With the added power draw this is another big wedge and means ill have to forfeit the controller with the £30 one off eBay.
I get that it is better to spend more on a CNC router but at a point it starts to run over budget :p
18-02-2017 #2
I'm guessing something like this http://www.zappautomation.co.uk/elec...er-supply.html
Yeah these things can snowball, one more expensive item leads to another and so on... reality is most of us are working to a budget so you need to figure out what you are willing to spend and what will be sufficient for your needs.
If budget is starting to pinch, I would also take a look at what areas it's best to put your money into initially. Might be an idea to go for the better controller (e.g. the CSMIO IP/M mentioned above) and just make do with the cheaper steppers until you feel the need to upgrade.
Ultimately of course you end up spending more by buying cheap then replacing, but reality is it gets you up and running in the mean time.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
18-02-2017 #3
Yea, I am thinking around £1,500 max.
Probably will go for these switching power supplies at first and upgrade later to the better power.
Would allow me to then have the nice steppers and drivers.
But I would also be using the cheap Chinese controller.
That will probably get me started for now. If I then need to upgrade in a few months at least I have done this project and hopefully have another one where I can spend a few more quid on nicer things if they are needed.
Looking at the parts on the one I listed; https://www.aliexpress.com/item/6040...999.277.umjtYe
Isn't the Y rail supported underneath?
I know it is not linear rails but should be better than the rods just floating?
The X axis ones are floating by the looks of it.Last edited by JOGARA; 18-02-2017 at 01:53 PM.
18-02-2017 #4A toroidal transformer 24-0-24v in series with one rectifier and two capsCan I ask what power solution you are using to get 68v?..Clive
18-02-2017 #5
Actually, I'm using a 2x45V toroidal with both windings strapped in parallel to give a single 650W supply. Same thing, really!
My first router used LinuxCNC (cheap - nothing cheaper, in fact) and a parallel port to a cheap breakout board. No spindle (speed or start/stop) control. Old analogue drivers. It worked. Not ideal in many ways, but you don't always need "the best". But you do need something that works for you, and it does need to be reasonably reliable. Best thing, I guess, is to try to understand what compromises you are making by going cheaper and deciding if you can accept that for the time being. The other thing to keep in mind is, "Can I easily upgrade it later?" For example, changing a motion controller or stepper drivers is not too invasive. But changing ballscrews for leadscrews, or supported rails for profile rails, might be more difficult later.
I have probable spent around £2500 on my steel-framed, ballscrewed, profile railed, motion-controlled, 1500x750 router. That's probably typical.
25-02-2017 #6
Would something like one of this work?
http://www.airlinktransformers.com/c...Filter+Results
They have 70+70V so would mean 2 sets of 70V?
From what I know, you can connect these in parallel though you have to be careful to get the phases the correct way round?
As for the rating, thinking 2000VA?
As for caps, 110v and as big as i'd like?
25-02-2017 #7
Ok what DC voltage to you want to end up with. What steppers are you using and how many.
Read #31 again 650VA should be more than enough try and get caps that are 100V
http://www.airlinktransformers.com/c...Filter+ResultsLast edited by Clive S; 25-02-2017 at 08:18 PM.
25-02-2017 #8
Going off what people said, higher voltage the better? So close to the max of the drivers.
As for the drivers, http://www.zappautomation.co.uk/elec...ion/em806.html (buying direct from manufacturer in China)
Steppers, http://www.zappautomation.co.uk/elec...ion/em806.html
25-02-2017 #9
...which is what you will get if you use a lower voltage transformer. Yes, I know it doesn't sound right, but in practice a 45V or so transformer will end up giving you around 68V DC across the smoothing capacitor(s). This also gives a bit of allowance for the fact that the mains input voltage will vary, and the transformer will probably give you about 5% over the rated voltage under light load to allow for a drop when on full load.
EM806 are good drivers.
25-02-2017 #10
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
