    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by JOGARA View Post
    Would something like one of this work?
    http://www.airlinktransformers.com/c...Filter+Results
    They have 70+70V so would mean 2 sets of 70V?
    From what I know, you can connect these in parallel though you have to be careful to get the phases the correct way round?
    As for the rating, thinking 2000VA?
    As for caps, 110v and as big as i'd like?
    Ok what DC voltage to you want to end up with. What steppers are you using and how many.
    Read #31 again 650VA should be more than enough try and get caps that are 100V
    Going off what people said, higher voltage the better? So close to the max of the drivers.
    As for the drivers, http://www.zappautomation.co.uk/elec...ion/em806.html (buying direct from manufacturer in China)
    Steppers, http://www.zappautomation.co.uk/elec...ion/em806.html
    ...which is what you will get if you use a lower voltage transformer. Yes, I know it doesn't sound right, but in practice a 45V or so transformer will end up giving you around 68V DC across the smoothing capacitor(s). This also gives a bit of allowance for the fact that the mains input voltage will vary, and the transformer will probably give you about 5% over the rated voltage under light load to allow for a drop when on full load.
    EM806 are good drivers.
    Those are 80V drives so run them at about 68V to allow for the back emf. 24-24 v in series = 48 = about 68V dc when rectified.
    AM882 drives would be less dosh and just as good.
    Snap
    Ohhh
    I thought it was 1:1 from transform through rectification.
    That makes sense why so many are doing 24-24v.
    These are the drivers I am getting https://www.aliexpress.com/store/pro...615.0.0.9rnD8Q
    Forgot I changed to them.
    Am I right in saying that when the steppers start up or change direction, they require a lot of amps, but when they are going it is pretty low.
    Which is why you are able to get away with lower wattage transformers?
    A 625 va trans former will be fine good choice on the AM882
    Doing an order from TME already, saw they sold toroidals.
    http://www.tme.eu/gb/details/tst600w...del/tst600008/
    Though it is 600VA not 650VA.
    That extra few watts going to make much difference?
    Doing an order from TME already, saw they did toroidals.
    That will be fine
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
