17-04-2017 #11
Which bits are those?
Side finish is a bit poor, looks like a lot of chatter. Chips are also a bit small and fluffy suggesting too slow a feed rate. What bits and what feeds/speeds?
This is the sort of wall finish you should be able to get out of this machine with a bit of practise
You can set max depth under multiple passes in fusion, even on the adaptive stuff.Last edited by Zeeflyboy; 17-04-2017 at 08:28 PM.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
