Looks a bit better, see my edit just above your last post for some further thoughts.
17-04-2017 #2
Saw it and will be testing it out tomorrow!
Also, just found a 2 flute 6mm...
Must have come with the machine xD
Might give that ago tomorrow too..
Mobile footage of the last cut.
17-04-2017 #3
looks pretty good in the video
I found the cutters that came with the machine fairly crap btw
17-04-2017 #4
18-04-2017 #5
This is the latest result.
Forgot to mention that I am not doing a finishing pass yet.
18-04-2017 #6
Cut my product's case rear end.
Not perfect. Some work to do on the CAM but in terms of output it is great.
Really do need a chamfer bit...
18-04-2017 #7
So I started playing with the 6mm that was included. Worked well at first.
Was getting some nice test cuts with it so decided to give it ago milling out my case.
Working well for a good 45 mins. I had the feed rate at 200% as my stock settings was making quite a fine chip.
Having it at 200% made a much nicer chip that flew straight off.
It got to about 2/3s the way down the 15mm bit of aluminium and the sound frequency changed.
Went to check it out and I went to pause it but suddenly the bit started to get hot so the chips welded onto the bit.
Doh
Obviously can't go that fast when the ali has warmed up and you are doing 2mm cuts.
Was only air cooling though. I found water kept clogging up the chips and well I don't have any proper coolant system or liquid...
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
