  1. #10
    Normal double sided carpet tape works but you can actually hear the difference compared to a proper clamped mounting in the amount of vibration it allows. You can also see chips "dancing" on the surface which shows the part is vibrating... I wouldn't recommend it for where tight tolerances or good finish is required - much better to get a good fixture plate sorted out.
    I use the TPA-2 here (in stock now, though with a smaller stylus I think which may actually be better for our purposes) http://www.kurokesu.com/shop/TPA2
    As mentioned though, in this particular scenario it won't do much you couldn't do with a tool steel rod and a micrometer. If you don't already own one you also need to feature in the cost of a decent dial indicator to allow you to get the ball centred.
    For your particular scenario here I may even be tempted to machine a small vacuum fixture plate which will hold the parts in alignment and hold down the part whilst allowing you to machine the exterior in a single operation. I think you will never be happy with finish unless you allow it to machine the full exterior depth in a single op. Even a tiny misalignment will show in the finish.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
