    Good point about the soft jaws.
    Stick at it. Flipping is an acquired art. I would really consider the approach I suggested a few pages back with a fixture plate to use for location and fixing after the flip. It's really quick and easy to make and use and well worth the hour or two it takes to make if you have more than a few parts to make.
    No idea where to start in terms of making a fixture plate for these cases...
    Vice is easy as I just chop out of the soft jaws the profile of what I am holding.
    I have a feeling that this cheap vice is my major problem but also finding the work edge too.
    I am now working from the center of my stock/part and using the external sides and halving them to find it, but I am finding it is still off a bit. I think that is more down to the inaccuracy of my probe setup if anything.
    All you need for a fixture plate is a method for locating and holding the part and a feature to zero off.
    I use dowel pins for locating, all you need is enough space on what will be your bottom surface after the flip for drilling two dowel holes. For fixing I don't think I've ever made anything that doesn't have a spare hole or two to put a bolt through to hold it down, on your cases you could just use stick a bolt through the big square holes with a large washer to grip the sides (one of the clamps that came with the OMIO would do). When you need to do an op on/around one of those bolt holes you just program a pause in your toolpath, move the bolt elsewhere on the part and carry on. For x/y zero I drill and ream a nice round hole to zero off, this is obviously at a known location because you have modeled it in CAD, the same goes for the dowel pins, and therefore from your X and Y zero feature you know where everything is to within the tolerance of your hole and dowel pin sizes, which I've never been off more than 0.2mm across the full 355mm length of the X. Z zero for me is always the top of the fixture plate, then when you're facing down the top of your part you know you are bringing it down to an accurate size.
    If that makes sense?
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
