  1. #10
    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by JOGARA View Post
    My current system is one of those cheap bendy hoses with air and "mist".
    I have pretty decent air going through it with a tiny amount of regular water and have not had any chip welds.
    Probably could do with some sort of coolant fluid or additive in the water though to assist.
    Is the air flow enough to blow the chips well out the way?
    Provided it's keeping chips well away from the cutter, then your setup should be fine. Even if you have to give an extra blast occasionally, it sounds like you've got a reasonable setup, and I wouldn't worry.
    It might be worth trying some of the misting fluids though. This is what I used to use - http://www.johnnealeltd.co.uk/shopenvirocutse10.html
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
