  1. #10
    Is the air flow enough to blow the chips well out the way?
    Provided it's keeping chips well away from the cutter, then your setup should be fine. Even if you have to give an extra blast occasionally, it sounds like you've got a reasonable setup, and I wouldn't worry.
    It might be worth trying some of the misting fluids though. This is what I used to use - http://www.johnnealeltd.co.uk/shopenvirocutse10.html
    Yea the chips fly miles. I found tiny amounts of water and decent air meant that 99% of the chips left my stock area.
    The ones left tend to stick along the walls of my part. Not a massive problem as I then go around with my finishing path and I do that dry (only taking off 0.25mm) and that clears whatever is left from me brushing away the majority of leftovers.
    That Envirocut SE10 looks good. I like that it is biodegradable. I am using a tiny amount of coolant as it is so 1L should do me for a while?
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
