27-01-2018 #1Z is 0.2mm high at one side of the vice on the Y-axis. X-axis there is no difference...Clive
27-01-2018 #2
28-01-2018 #3
Dam it. I forgot that I have an operation where I need to stand the 105mm tall part on its end to mill out connector holes...
I do have a tiny vice that I could use for this. Might be able to fit it in behind the new vice, will be hard to reach but really is it my only option :/
28-01-2018 #4
Great way to firm up the 6040 bed. . . . . . .Replace virtually the entire bed with an enormous vice!
I think it looks good.
The Following User Says Thank You to AndyGuid For This Useful Post:
30-01-2018 #5
How true is AW's "flat bar" stock?
Like do I need to order the size up of what I want to make it true over 150-200mm lenth of cut?
30-01-2018 #6
Best to buy bigger stock, hold on a few mm and do as much as you can on the first op then turn over and take the back off. The flat Ali bar won't be square so will cause more problems later if you don't square it up. Don't buy from aw either find a big metal supplier like smiths metal centres, it will work out a lot cheaper.
30-01-2018 #7
The stuff I was looing at would allow 5mm to be shaved off each side actually (made my part smaller).
Ill contact a few local companies. I have been using AW just for ease. But I have spent nearly £200 this past week which probably would have been a lot less locally xD
31-01-2018 #8
FUCKKKK
Just snapped the probe.
Anyone know if there are other probe ends that fit this one?
http://www.kurokesu.com/shop/precision_instruments/TPA2Last edited by JOGARA; 31-01-2018 at 01:11 PM.
There are currently 27 users browsing this thread. (0 members and 27 guests)
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
