New Styli just arrived. Trying out the Renishaw ones as they are distributed and possibly manufactured in the UK?
The cheapest M3 with 3mm ball is 21.2mm long (ball end being closer to 2.9mm diameter than 3mm, this typical?).
The shorter length actually works well for me as with the new vice installed, I don't have much Z height anymore.
https://www.renishaw.com/shop/Produc...ct=A-5000-3553
£49 for 2 probes, shipped next day (I ordered past 5pm so same say shipped) and was sent first so arrived today.
Bit better than the 100 Euro the dude who makes these probes quoted me for a single Styli...
[edit]
Shipped same day if ordered before 2:30 pm and they are made in the UK.
I have an image just above of the Styli but image host is playing up.Last edited by JOGARA; 08-02-2018 at 06:13 PM.
08-02-2018 #2
09-02-2018 #3
Nice. Looks like the vice is giving you much better results so worth every penny if it gets the job done.
For chatter if you're using HSM toolpaths full depth and shallow step over try using a bigger 8mm or 10mm tool. 6mm drill should be absolutely fine, I have absolutely zero problems doing a 6.
09-02-2018 #4
Yea it was a sound investment.
While it sounded like there was chatter, I could not feel anything in the part. Though I did do a contour finishing pass which would have hidden it I guess.
As for HSM, idk if that is what I am doing or not. Not sure what classes HSM. Currently I am taking a DOC that is 50% the width of the tool with a 45% step over.
The only problem I am having ATM is doing a chamfer. For some reason it is quite uneven around the part.
Looks like the part when clamped is lifting a hair but even so, it is low on that corner.
Can only guess that it is not being perfectly probed or the vice is out by a hair?Last edited by JOGARA; 09-02-2018 at 10:55 PM.
10-02-2018 #5
If you're using fusion, use the adaptive tool path for clearing metal out. I've cut down to 13mm Doc with my OMIO, between 0.3/0.4mm step over. You can go wider if you're cutting shallower. Better for tool life too as you're using more of the tool than just constantly using the tip.
Skim off the top of the part so it's all perpendicular to your gantry and spindle then your chamfers should be even. A light rub with sandpaper and a quick splash with polish to remove the tool marks and it will look much better than the grainy texture on the top of the extrusion as well.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
