10-02-2018 #15
8mm DOC, 0.5mm max stepover.
Cut fine, no noise, looks like I can go deeper.
Going to attempt 1mm. Can always pull it back.
This is much better than the 1hour+ than before. Down to 15mins now :)
The spindle is out but only by a hair. I can feel on the contour pass a slight line going around 2 sides of the part.
I have lowered the contour pass to take 4 depths instead of 2, this fixed that problem last time.
I am also getting this again on the contor. I have a 10mm finishing overlap. But I used default lead-in. I have upped that to 2mm. Hopefully that stops that.
And yes, I forgot to go -0.1mm on the contor pass so there is a bur going around the bottom of the part. The roughing pass went -0.2mm, so I normally set -0.1mm for the finishing endmill.Last edited by JOGARA; 10-02-2018 at 05:06 PM.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
