10-02-2018 #20
If you're using fusion, use the adaptive tool path for clearing metal out. I've cut down to 13mm Doc with my OMIO, between 0.3/0.4mm step over. You can go wider if you're cutting shallower. Better for tool life too as you're using more of the tool than just constantly using the tip.
Skim off the top of the part so it's all perpendicular to your gantry and spindle then your chamfers should be even. A light rub with sandpaper and a quick splash with polish to remove the tool marks and it will look much better than the grainy texture on the top of the extrusion as well.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
