    Chaz's Avatar
    Quote Originally Posted by Snapper View Post
    Are you using tooling plate to cut your parts from? That must be costing you a bloody fortune!
    Its not much more than standard Alu. The fact that its reasonably flat has many benefits.
    This /\
    Wanted to reduce my machining time so was faster to have the top and bottom already finished.
    That being said, sometimes one side does have marks on it that won't work for a finsihed product.
    Most of the time it is only on one side so I mill into that side while leaving the pretty face the to outer face that I see.
    What I might be moving towards is bar stock so I can grab it in my vice and not have to glue my stock to a large plate.
    Though I like maching the top and bottom at the same time as there are 4-5 tool changes.
    If I have ATC then that would not be a problem...
    Maybe for little odd jobs but for production? At a guess it's about 50% dearer than just buying a bar isn't it?
    Going off AW, 5083 bar worked out more expensive than Plate.
    Both cut to size.
    This is AW though...
    Nowhere near 50% more like 10% if that and the savings in machine time can easily justify that. I rarely buy bar stock anymore
    Keep getting this strange behaviour from the machine.
    Just keeps stuttering, even when just going along a straight path on 1 axis it will judder a lot.
    Does it every so often and most of the time I have to turn it off and on again.
    Any ideas?
    Quote Originally Posted by JOGARA View Post
    Any ideas?
    https://photos.app.goo.gl/uAcR70B7vQtYLvs22
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    Sounds like chatter to me..
    Correct it is resonance. Either lower your rpm or up your feedrate.....a lot. This is where having a machine with no rigidity and physical weight plays a big part and restricts what you can do, there is only so far you can push a machine like that.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
