24-01-2018 #261
24-01-2018 #262
Ordered that vice and a new plate for leveling it.
Just saw this on FaceBook. No idea why I haven't seen this idea posted around before. Would have saved hours.
Will be testing it with this new vice.
Wait. Could have just printed a holder for the part and mounted it onto the base of the cnc machine....
Well at least the new vice will be a good paper weight...
Thanks.
I have emailed them to see if they can confirm what size.
The gap at the top is 8.5mm and the OD of the threads is 7mm.
Can't pull them out atm as the machine is running.Last edited by JOGARA; 24-01-2018 at 05:37 PM.
24-01-2018 #263
You do realise those MarkForged jaws aren't plastic?
MarkForged produce carbon fiber and metal 3D printers.
I never seen the Gerardi vice offer :-/
I'll give Cutwel a call once I'm feeling a bit more flush, as I could really do with behaving for a couple months to let finances recover from last years expenses.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
24-01-2018 #264
24-01-2018 #265
I would think so for chamfering.
I'm not sure I'd trust them for anything involving much higher cutting forces though, but there is only way to find out..Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
25-01-2018 #266
25-01-2018 #267
Bit of Googlering and a few people are saying that it is M8 that one wants.
Yea shipping on KJN.
RS does some extrusion stuff though, these look about right?
https://uk.rs-online.com/web/p/conne...nents/3900379/
25-01-2018 #268
You don't want m8. You will constantly be fighting to get the bolts through the slots and threaded in the nuts and there is absolutely no need for that much clamping force. M4 or m5 will be just as good, I used m6 because I have a tonne of m6 fixings in all sizes which is important. If you use rs the ones linked or these are the ones you want but not in m8.
https://uk.rs-online.com/mobile/p/co...nents/3900256/
You also don't want to be thinking about using anything 3D printed if accuracy and repeatability is what you're after.Last edited by Snapper; 25-01-2018 at 08:23 PM.
26-01-2018 #269
Just a thought here which I should have thought of sooner. You are aware of the sheer weight of a proper machine vice? I don't think the flimsy hollow extruded aluminium table that comes on the OMIO will give you much improved results. The bed will dip and probably bounce around like a trampoline. Think about that and try some tests before you actually use the vice and can no longer return it.
26-01-2018 #270
There are currently 32 users browsing this thread. (0 members and 32 guests)
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
