Page 34 of 36 FirstFirst ... 243233343536 LastLast
  1. #331
    Quote Originally Posted by JOGARA View Post
    Close to calling it quits on this and going a different route. Though I would have to sell everything to afford said different route.
    Anyone want to buy this machine?
    Sorry but what did you expect.? It's cheap chinese Router which was never designed to cut hard materials to any degree of precision.! Your expecting too much from it.
  2. #332
    Any ideas on how to fix the machine?
    1. Identify the axis which is out of alignment
    2. Identify what should put it/keep it in alignment
    3. Post photos and ask for suggestions
    It sounds like you've knocked it out of alignment by hammering it beyond it's capability, you may be able to hammer it back.
    It's a great idea to fix it, it's probably something that way, when asked what broken machinery is worth I always quote the Rag and Bone Man's opening gambit to children - Tuppence and a Balloon :D (I'd actually give about £50 as I could use some of the parts for a 3D printer build I'm on with ;-) )
  3. #333
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    There is always the bodge option.
    Machine the parts so that the out of squareness matches up.
  4. #334
    Been thinking about doing that. Does not impact the internals of the case as we built in tolerance to the PCBs.
  5. #335
    As you know I have the same machine. I have wasted too many hours hammering the gantry back and forth, shimming it, squaring the spindle etc.
    When alls said and done you have to realise this is a very entry point hobby machine that we are pushing to its limits cutting aluminium. Being made out of pieces of extruded aluminium bolted together, it moves. It moves with different atmospheric conditions, it moves under load/vibration from cutting aluminium.
    In my case my gantry was skewed radially and actually by about 2mm and 1mm respectively IIRC. I've had mine in pieces more times than I care to count trying to make it as good as I can, opening up holes, retapping threads, shimming it. It never stays square for long. In the end I've given up trying to keep everything square as it's a waste of time unless you have an hour to kill every time you set the machine up, and just accept that it is what it is and it makes what it makes.
    In your case you can solve the problem of your parts not matching by cutting one side the other way round, then the rhombus will match that of the other half, currently you have them opposing each other. Or you could cut them oversize initially then bolt them together and finish. The ones you've already made could be saved this way.
    And in regards to the conversation about controllers, unless OMIO changed controller between my purchase and his it does allow for jogging the spindle anywhere between tool changes, I've never had a problem.
  6. #336
    If you got the machine squared up you could put less load on it with a single flute cutter and a ramped profile cut where the cut depth is considerably less but the feed speed is higher.
  7. #337
    To fix the squareness the easiest way I found was to drill two holes for precision dowels in the Y-axis, then using a precision edge run a dial indicator along the X-axis with the precision edge clamped against the dowels. I then loosen bolts on the gantry and gently tap it in the direction required before re-tightening the bolts and re-checking. Repeat a few times and you will get it fairly close to square (although you will come to realise that your gantry is probably not flat, but bowed slightly leading to it being impossible to square out completely - I just tweak until the dial indicator reads the same at 1/4 and 3/4 travel).
    I ended up just having it as square as I could get it over the centre of the bed where I do most of my work, the squareness varies a little as you move around the bed due to the lack of straightness inherent in extrusions. I found it generally holds the square ok-ish after messing with it, but if you move it then you'll have to re-do.
    Ultimately I do think its good for the money as an entry point, but for really precise work you have to work within the limitations of the machine and spend a lot of time tweaking. The best option in terms of value for money is to take what you've learned from the machine (plus all your tooling and associated equipment) and use it when designing/following a design on here for building your own machine. The conclusion I came to is that while I've managed to make some really good stuff on it, it simply isn't worth fixing up or modding extensively as you end up chasing your own tail.
    That said I have managed to make some pretty precise parts with it, and it is still leagues ahead of the unsupported rail type 6040 machines.
  8. #338
    The road to go with this is very simple- buy a CNC mini mill. Fit a DDCSV controller and you will never have any problems. I have had 0 problems from the time i stopped using Mach3 for anything at all.
    You could start changing the controller anyway. And as they told you- using single flute mills. And reinforce all as much as possible as cheap as possible.
    Been a few months. Thought I would update this car crash of a thread with a little something.
    As some of you have seen already, I farmed out the work. Glad to say that it has gone really well and has actually save a lot of my time and was totaly worth it.
    Went with Scott from Ward Engineering.
    Helped me a lot with creating better models for faster and more efficient machining and general things like adding some margin for the powder coat and tolerances.
    Overall I could not be any happier. They turned out great and I think I have nearly 40 of this style of case.
    Currently have close to 80 more cases being made right now and hopefully around 25 of another part
    I should note we did save a few pennies on tooling as these are being powder coated.
    Powder coated in house...
    I am broke now though so if anyone wants to buy the 80mm spindle LED ring lights from me, either as a blank PCB or as a kit or fully assembled let me know :p
    https://postimg.cc/image/6z04kkomf/
    https://postimg.cc/image/l5fvftucn/
  10. #340
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Nice work Scott. And that's the difference between Hobby or not.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
