18-10-2020 #36
You are still cutting well below what you probably could. Don't be afraid to experiment, you'll be plesantly surprised how much faster or deeper you can cut.
You don't mention the tool material HSS or carbide.? or the DOC.
If tool is HSS then try 2mm DOC 900mm/min 20,000rpm, you could probably easily cut at 3mm DOC but 2mm will be safer start point.
If tool is carbide then try 1250mm/min 24,000rpm 3mm DOC and work up from there. Carbide tooling works best when it's being pushed hard so don't be afraid to give it some welly.
The machine will be the weak link when it comes to carbide tools as you push harder because it will vibrate and carbide doesn't like vibrations or chatter as it's quite brittle, the chatter cause it to chip the cutting edges which then leads to excess heat and if bad chatter will snap the cutter.
HSS is more forgiving but can't be pushed hard like Carbide can and wears more quickly losing it's cutting edges faster.
Just remember the deeper you cut the more important chip evactuation becomes so make sure you have dust extraction fitted.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
There are currently 14 users browsing this thread. (0 members and 14 guests)
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
