	15-02-2017 #1I love machining Acetal, it chips beautifully gives a nice smooth finish. Cant comment on the Ting G controller but if this is potentially for business then I'd build your own control panel, make your own PSU etc. etc. You'll be updrading the 6040 after a while so at least you'd have decent electronics...
    The Following User Says Thank You to njhussey For This Useful Post:
	15-02-2017 #2I was looking at this stuff. https://www.cutplasticsheeting.co.uk...-polypropylene
 Cost wise it is perfect and I can get it in good little custom sized sheets that will do one case each.
 Googled "hard polyurethane" but not seeing much. Got some more info on that Robin?
 Not heard of Acetal before, though I am no plastics expert :p
 Will take a look at it.
 I would like to encase the machine once I get it all setup and working though this will be after the production run due to limited time.
 Plan on having it in a tower case like a HAAS milling machine mainly so it is all self contained and can be plugged in and turned on.
 Moving house soon so having it like that will help with storage and keeping stuff clean.
 My main thing about the electronics is having it sort of reliable long term.
 I would like to just be able to turn it on and not have a problem that then takes a day or a week to fix because the China circuit board decided to blow up or drivers die...Last edited by JOGARA; 15-02-2017 at 09:28 PM.
  New 6040 owner looking for advice from others with a chinese 6040/3040By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM
  Newbie question re converting my 6040 machine to use a laserBy GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM
  10 / 15mm thick 6061 aluminium alloy sheet ?By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM
  FOR SALE: Polypropylene compoundBy Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM
  NEW MEMBER: Newbie From ChinaBy jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
