17-02-2017 #2
Isn't there a way to dump excess power coming back from steppers?
Like resistors or something.
17-02-2017 #3
Unfortunately not. There are two main problems with the switch-mode PSUs in this application, although they are great and very cost-effective elsewhere. One is the back emf issue as mentioned, while linear power supplies dump excess power into the smoothing caps (one way to look at it, anyway). The other is that linear supplies are much more tolerant of peak overload. A switch-mode supply tends to hard-limit, maybe even shut down temporarily, if you try to draw more than rated current where a linear supply output will tend to just sag a bit which is not usually a problem. If you are now looking at Mach3, you might also consider something like a UC100 or UC300 with UCCNC which is looking like an attractive option these days. Still need a break-out board but it's a better option than using Mach3 and parallel port.
17-02-2017 #4
Okay, so I looked into toroidal based supplies and they are easy to make. So should be no time to spin a board for one of those.
Do cost a bit to get them off the self, though I know of a place that do them for like 50 euros each at any spec you want.
So might be able to get a decent high amp one for not that much more.
The problem is, the high voltage stepper controllers are not Chinese cheap :p
Looking at £110 per axis :/
I have only looked on Zapp though so far.
Steppers themselves are around £30 each. Makes it around double the cost.
But I guess it is worth it because of needing that extra speed and power?
Regarding the steppers, they state a "Rated Voltage" of around 2-4v.
Do the drivers lower to voltage or because they pulse the stepper they are able to use upwards of 80v?
17-02-2017 #5
Ignore stepper voltage ratings. As you say, the stepper driver effectively pulses the drive voltage; the driver manages the current rather than voltage but the higher voltage allows higher current pulses which helps develop torque. Confused me at first but the stepper driver will have an adjustable current setting which is more useful. That's also why you use a linear power supply - better current pulse capability.
17-02-2017 #6
Thought it was along that line.
As for picking what steppers to get.
Higher amp rating, higher holding torque are what to look out for?
Looking at Zapp, http://www.zappautomation.co.uk/elec...per-motor.html
The drivers; http://www.zappautomation.co.uk/elec...ion/em806.html
Looks to be the best at the £100-120 option.
80V and 8.2A.
Wondering what controller to get too..
17-02-2017 #7
Or if you don't mind China https://www.aliexpress.com/store/pro...783794956.html
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
