Ok what DC voltage to you want to end up with. What steppers are you using and how many.
Read #31 again 650VA should be more than enough try and get caps that are 100V
http://www.airlinktransformers.com/c...Filter+ResultsLast edited by Clive S; 25-02-2017 at 08:18 PM.
25-02-2017 #2
Going off what people said, higher voltage the better? So close to the max of the drivers.
As for the drivers, http://www.zappautomation.co.uk/elec...ion/em806.html (buying direct from manufacturer in China)
Steppers, http://www.zappautomation.co.uk/elec...ion/em806.html
25-02-2017 #3
...which is what you will get if you use a lower voltage transformer. Yes, I know it doesn't sound right, but in practice a 45V or so transformer will end up giving you around 68V DC across the smoothing capacitor(s). This also gives a bit of allowance for the fact that the mains input voltage will vary, and the transformer will probably give you about 5% over the rated voltage under light load to allow for a drop when on full load.
EM806 are good drivers.
25-02-2017 #4
25-02-2017 #5
Snap
25-02-2017 #6
Ohhh
I thought it was 1:1 from transform through rectification.
That makes sense why so many are doing 24-24v.
These are the drivers I am getting https://www.aliexpress.com/store/pro...615.0.0.9rnD8Q
Forgot I changed to them.
Am I right in saying that when the steppers start up or change direction, they require a lot of amps, but when they are going it is pretty low.
Which is why you are able to get away with lower wattage transformers?
25-02-2017 #7Am I right in saying that when the steppers start up or change direction, they require a lot of amps, but when they are going it is pretty low.
Which is why you are able to get away with lower wattage transformers?Last edited by Clive S; 16-03-2017 at 10:43 PM.
16-03-2017 #8
Doing an order from TME already, saw they sold toroidals.
http://www.tme.eu/gb/details/tst600w...del/tst600008/
Though it is 600VA not 650VA.
That extra few watts going to make much difference?Last edited by JOGARA; 16-03-2017 at 10:44 PM.
16-03-2017 #9
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
