    Cheers on the machine!. Sth is not right with that wood cut. Try 16000- 17000rpm, bit diamenter depth of cut and 60IPM / 1500mm/min. That generally will work on any machine, even a flimsy one. 16000-17000 on soft wood, 17000-18000 on hard wood. Mdf and similar.
  2. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  3. #2
    Just got my new vice. Decided against the 2 cheap ones from China that cost £100. Went with a single one for £80 that is built for "light milling". Feels solid enough for what I need.
    Holds my 150x100 aluminium perfectly and there is room to put bigger bits in there.
    Will work on the mounting of it to the base though.
    Only getting 1-2 hours a night to play with it all atm.
    Got to finish a load of uni work :/
    Also need to work on my speeds and feeds...
    looks like it should be fine.
    Just beware that your bed won't be level, so bolting the clamp directly to the bed won't give you a level surface either.
    Ideally you need to bolt on a spoil board of some description and use the machine to skim it down. That will give you a flat surface to screw the clamp down into.
  5. #4
    Yea I heard about that being a problem and looks like it is a bit off.
    Wood enough for a spoil board when working with aluminium?
  6. #5
    MDF or similar would be ok as long as you aren't using much coolant. If you have any moisture resistant lying around that is a bit more stable in terms of dimensions and changes in humidity etc but far from essential.
    You could also just bolt down a small piece where you intend to put your vice, rather than the whole bed. You would just have to re-skim it if you remove it but that's not a big deal for a small piece like that.
  7. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  8. #6
    That's a good idea. I was planning on keeping the vice at the far left side and leaving the rest available to other projects that I need to do.
  9. #7
    So this is the case that I am milling out of EcoCast.
    These are the end mills I have so far.
    3.175mm http://www.ebay.co.uk/itm/1824106825...%3AMEBIDX%3AIT
    2mm https://www.aliexpress.com/item/10pc...608.0.0.EJZ3Jx
    1mm https://www.aliexpress.com/item/10pc...608.0.0.EJZ3Jx
    The case is like 75x60mm so I don't want to carve that all out with a 3.175.
    Was thinking of getting something along the lines of a 6mm end mill to do the main hogging out.
    What is the max these spindles can take?
    I have collets up to 12mm.
    Also, where is the best place to learn speeds and feeds? I have been testing these 3mm on a bit of this EcoCast and broke 2 end mills within minutes.
    One I accidentally knocked into the work piece. The other because I did not know how to correctly set up the Z in Fusion CAM.
  10. Have you thought about using foam etc. to practise on that way it will be more forgiving when you dive into it.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
