18-04-2017 #11
If you are getting fine chips or dust, rather than upping your feed consider dropping your rpm to keep the material removal rate at a reasonable level... it will help control the heat production and reduce issues with tool deflection/chatter when compared to ramping up the feed rate. You need quite a rigid machine to get away with the high feed rates associated with faster rpm.
Bear in mind of course that these spindles don't really like much below 12k rpm for sustained periods. Coolant allows you to sustain a higher removal rate than dry cutting of course, but it isn't absolutely vital for good results it just makes dialing in those feeds/speeds a bit more critical. Chips do look better in that pic above.
This is where single flute give an advantage as you are effectively running at half the rpm vs a comparable 2 flute bit.Last edited by Zeeflyboy; 18-04-2017 at 04:27 PM.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
