  1. #9
    So I am having much better luck today.
    The probe is 0.1-0.2mm out on both X and Y but I think I am starting to see a pattern so should be able to just offset it next round.
    Did end up with 0.2mm out on the Y with these cases but they are not being sold.
    I keep getting this bump on the Y face. It is only a hair deep but you can visually see it and feel it.
    It is where the operation starts and ends so I am guessing it is something to do with that, not having enough overlap to smooth it out if the bit is coming off the part too quickly?
    My soft jaws work really well for holding the cases. Though these were milled back in the day and are not level any more. Probably because I removed them and put them back.
    Don't think my vice is all that accurate as well, it not being a proper machinist vice does not help.
    I wanted to get one but even on eBay they were £500 for the width I need.
    As you can see in the second photo, they result in the chamfer being messed up on one of the edges.
    Was able to do a nice chamfer on the button and other front face holes for electronic components.
    Oh and instead of milling out 2-3mm of my mounting holes which I then had to go drill deeper anyway.
    Used the chamfer bit to spot the holes so I can just do them on the drill press.
    I was already doing them anyway as my 1mm endmill is only 5mm long and I need a few more mm depth.
    Other holes like the big one in the middle needed to go all the way down which I can't do with a 3mm endmill that is 5mm long. Do have the 15mm long one that would work but rather just drill it with a 4.5mm that use machine time and an expensive bit...
    Obviously the chamfer bit is not made for this, will be swapping it out for a spot drill bit once it arrives.
    I have looked at drilling with the mill. I tried it but got horrid results. Though it was probably down to bad setup. Not sure if this machine is really capable of drilling though. Thoughts? https://www.shop-apt.co.uk/carbide-d...d-series-.html
    [edit] Just taken out the parts from the vibratory tumbler and they are looking great.
    Really love that thing. They go in for 4 hours and come out great.
    So smooth even with some sharp edges. Shame it is such a pain to clean out, not done it yet but that drain port I need to fix...
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
