    Quote Originally Posted by Snapper View Post
    I wouldn't use carbide bits on a drill press, particularly not that small. Your chuck likely has a fair bit of runout and carbide will snap in it like a digestive biscuit.
    Good point.
    Not having much luck today.
    1 HSS and 1 Carbide down so far and I have only been in the shop for a couple hours -_-
    Gives me an excuse to buy some more bits.
    Grabbed a 1.2mm for my M1.6 tapped holes (probably swap for 0.3mm as M1.6 holes are meant to be tapped at 1.25mm not 1.2mm).
    Also got a 2.5mm for my M3 tapped holes and a spot drill.
    Not sure what is going on here.
    I have not used the machine in a few days, like 5-7 days.
    When I go to home all the axis the Z does not stop when it hits the end stop.
    Forgot how I fixed it last time it did this about 1.5 weeks ago.
    Also, sometimes when I set my part offsets and then tell it to go to the part's zero, the Z will go about 5-10mm below the set Z. I then tell it to go to zero again and it lifts Z to the correct height.
    [edit]
    Why is it also normally open? Would have thought NC would be safer?
    [edit2]
    Gone into diagnostics and all but the Z axis limit switches are working.
    The switch its self is working so guessing cable problem.
    [edit]
    Yea it is cable..
    I have the same thing with the go to zero command, always goes to Z-5, I just don't use it and use g0 x0 y0 if I ever need to go there for any reason. Keep meaning to look in to it but always forget.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
