14-11-2017 #8
There is no stock to leave. Z height is all the same for all the operations.
I am using the 6mm roughing bit for most of the milling on this part. It does all the surfaces too.
I just ran the operation again but specificity all the heights manually from stock bottom and now it is just 0.3mm out.
The towers are all the correct height which is okay. But the bottom being so far down means my PCBs don't sit and the part that sits in the curved section is not being clamped down, it is just lose as there is 0.6mm too much Z.
This is definitely something in my Fusion operation.
I do have the minimum Z DOC at 0.5, so why it is cutting down at something not divisible to that, idk..
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM -
10 / 15mm thick 6061 aluminium alloy sheet ?
By rnr107 in forum Marketplace DiscussionReplies: 10Last Post: 14-01-2014, 12:15 AM -
FOR SALE: Polypropylene compound
By Bjh1985 in forum Items For SaleReplies: 0Last Post: 08-09-2013, 09:39 AM -
NEW MEMBER: Newbie From China
By jenniferxu in forum New Member IntroductionsReplies: 1Last Post: 04-01-2011, 06:02 PM
