    6082 is better to machine.
    Why don't you get 6" x 3/4" flat bar billeted and machine all over. It will work out cheaper.
    Quote Originally Posted by jamesgates1000 View Post
    idk
    Always used "eco cast" from AW. Apparently, it is 5083 but ground?
    Need to look into types of alloys. Hoping there is a decent YouTube video on it. Will check later.
    Just finished a part with the new vice and it is looking amazing!
    So much better than the drill press vice xD
    I'd post photos but my phone died...
    Here is the area of the part I was having problems with.
    The chamfer would be uneven. Now it is perfect.
    This is my contraption.
    I know a few will laugh but it works really well....
    Would prefer to machine the top in the vice and then flip in the vice.
    I hate the super glue and the removal of it (which even on fresh plastic is scuffing up the surface finish)
    Will try it once I have some soft jaws.
    Also, I got yelled at for running this tiny cut without lubricant..
    https://www.instagram.com/p/BenMhMghCqq/
    Making some nice chips...
    6mm, 25mm Flute. There is a bit of chatter when it goes Z- 10mm. But is holding up fine.
    I used a 6mm carbide drill to pre drill the holes. Worked out really well. Only a hair width of gap between the endmill and the stock but never heard it cut anything when dropping into the hole.
    The 6mm drill bit is pushing the machine a tad. Can see it flex at 0.2mm Feed per Revolution. Dropped it to 50% in Mach3 and it still flexed but very little.
    New Styli just arrived. Trying out the Renishaw ones as they are distributed and possibly manufactured in the UK?
    The cheapest M3 with 3mm ball is 21.2mm long (ball end being closer to 2.9mm diameter than 3mm, this typical?).
    The shorter length actually works well for me as with the new vice installed, I don't have much Z height anymore.
    https://www.renishaw.com/shop/Produc...ct=A-5000-3553
    £49 for 2 probes, shipped next day (I ordered past 5pm so same say shipped) and was sent first so arrived today.
    Bit better than the 100 Euro the dude who makes these probes quoted me for a single Styli...
    [edit]
    Shipped same day if ordered before 2:30 pm and they are made in the UK.
    I have an image just above of the Styli but image host is playing up.
    FFS it did it again.
    Jogging the machine towards the part, and it carries on. The remote shut off so you can't stop it till it decides to stop its self after 2-3 seconds.
    And today was going good till now...
    Quote Originally Posted by JOGARA View Post
    Nice. Looks like the vice is giving you much better results so worth every penny if it gets the job done.
    For chatter if you're using HSM toolpaths full depth and shallow step over try using a bigger 8mm or 10mm tool. 6mm drill should be absolutely fine, I have absolutely zero problems doing a 6.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
