Thread: Gluing Acrylic
    I have always bemoaned the fact that you can't buy chloroform in this crappy country, making it hard to cement acrylic with an optically clear joint.
    I just bought a litre of lab grade chloroform on Bay of Fleas, shipped from Italy of all places.
    Do you think it will get stopped by Customs? Even so, jolly exciting what!
    As long as Brexit is still just talk... it should not be stopped, but that does not make it entirely legal. I don't know the laws of UK, but even if it is OK to post a joint from Amsterdam, Holland (I have no idea if it is possible, just an example) it is not OK to order and receive it in Sweden. Drug trafficking is not part of the freedom of transporting goods within EU because it is regulated by a different law. I don't know if chloroform is classed as drug, but my guess is that it is, so it is probably not OK and if stopped then you will be in trouble if it is classed as drug in UK. If it is not classed as drug, it is probably classed as "dangerous goods and chemicals", which again is regulated by a different law, not the same as sending a piece of machinery or tools.
    Anyway, you probably know all that already...
    I make signs, there are proper chemicals now for bonding acrylic, I get the chloroform equivalent from Signs Metals & Plastics in Bromsgrove, it's called Fusion, it's syringable, the clear 2 pack adhesives are stronger on edge bonding
    Quote Originally Posted by Maxakarudy View Post
    That doesn't actually sound like much of a recommendation
    Before this H&S insanity every living room in the country had a record deck with a smoky acrylic cover glued together with chloroform. The joins were invisible and unbreakable, my cat kept her pet spider in one. Trapped by the smooth vertical walls she would bat it about to her hearts content. I thought about releasing it but the idea of my pet having a pet was too delicious
    Before this H&S insanity every living room in the country had a record deck with a smoky acrylic cover glued together with chloroform. :
    Some of us had separates that were decent kit though ;-)
    Ha - the joints on my smoky acrylic record deck cover were totally invisible as well. But that's because the cover was vacuum formed in one piece.
    It wasn't unbreakable though - wish I'd had some Chloroform then. :)
  1. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  2. Engraving/machining acrylic
    By andy_con in forum General Discussion
    Last Post: 03-11-2016, 04:15 PM
  3. Melting Acrylic/Plastic
    By Dwayne Dibbley in forum Machine Discussion
    Last Post: 15-07-2014, 04:30 PM
  4. Acrylic or mdf I can cnc
    By rainboweyes in forum Opportunities Available & Sought
    Last Post: 19-02-2013, 02:09 AM
  5. Acrylic suppliers
    By Web Goblin in forum General Discussion
    Last Post: 24-10-2011, 09:11 PM
