Thread: Z axis problem
17-02-2017 #1
Hi there, I'm having some weird things going on with the Z on my new machine. I set the tool up to zero on the top of the work surface but when the program is running the tool is about 3mm above. I've run the same on my machine at work and it's fine, any body know what's going on ?
17-02-2017 #2
Kev - your 100% on your g-code (goes down to z zero) - sorry I have to ask...
Any offsets in your tool tables?
17-02-2017 #3
Yeah I think so everything is set to zero except G54 which reads 41.075mm. I've even set the the gauge block setting to zero
I must be doing something wrong but I don't know what. But as I've said the program runs ok on my machine at work
17-02-2017 #4
Kev It is difficult for people to know how to answer if they have to start looking back through your posts to find out what you have done before or even what machine you have.
So how about keeping all the posts in one place as that would make it easier to follow. You need to supply more info and the procedure you have used to zero the tool etc. Even a sample of the first 20 lines of the gcode might help...Clive
17-02-2017 #5
17-02-2017 #6
Yep mach 3....I did swear a lot
Thanks for your reply
19-02-2017 #7
You could calibrate the z axis in mach3, I just cut a part set the tool height to 0 set the cut depth to 19mm but it would only cut 17mm then i figured out it was the z axis calibration in mach3 that needed setting problem fixed !!
19-02-2017 #8
Thanks I'll give that a go,
19-02-2017 #9
I have a chinese 6060 CNC.
It started to give problems with the Z Axis.
I eventually found the solution. The motor for Z is coonected to the shaft with a linc with 4 Allen key grub screws. By chance I found that two of the grub screws had never been fully tightened. As soon as did this everything worked perfectly. I suggest you give it a try. Of course this might not be your problem...Good luck Malcolm
19-02-2017 #10
This is the most likely cause.!
Another would be that that axis is binding or motors are over tuned. Both these things would cause your problem.
When you say use it at work are you using same this machine or another just like it.?
If it's this machine are you using same computer at work.?
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Problem with my Z axis
By mikem in forum Stepper & Servo MotorsReplies: 4Last Post: 03-11-2015, 11:52 PM -
Redsail laser engraver x axis problem
By sthdklen in forum Laser Machines & BuildingReplies: 4Last Post: 21-03-2015, 03:44 PM -
Problem with Mach 3 converted lathe x axis Boxford TCL 160
By FarrerDesign in forum Boxford LathesReplies: 5Last Post: 07-08-2013, 09:37 PM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM
