Thread: Pci or Ethernet motion control?
Thanks Clive
How easy is it to switch machines? have you got a switch box or just hot plug it?
I might have to try Linux from an lpt port to see how I get on with it.
I really want a plug and play system but they don't seem to exist :0)
19-02-2017 #2
With the 7i76 and 7i76E there are about 34 input and outputs with 5 axis two mpg's and spindle control encoder for threading A & B + index.
So I have both lathe and mill wired to the card and use the two mpg to do both.
I just select which config I want ie just one at a time.
I used to use the lathe from the PP with just a 100 slot disc plus index pulse and it was fine for threading.
PP has 5 inputs two were required for the encoder one for the O'shite button and two spare (could be z and x home)
The Following 2 Users Say Thank You to Clive S For This Useful Post:
CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
By dudz in forum CS-Lab (CSMIO)Replies: 35Last Post: 02-01-2017, 01:27 AM -
Any experience of Novusun Ethernet motion controllers?
By Doddy in forum Control Hardware & SystemsReplies: 0Last Post: 28-12-2016, 10:50 AM -
Motion control systems from China.
By nirmal in forum Motor Drivers & ControllersReplies: 7Last Post: 15-04-2016, 10:20 AM -
CNC Motion control
By StoneyCNC in forum Manufacturer NewsReplies: 1Last Post: 26-08-2013, 10:07 AM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM
