25-04-2017 #5
Just finished converting an AMAT25LV. Works nicely. Decent little machine with good service from Amadeal. They're just the bog standard rebadged chinese mill available all over the place but reasonable for the money.
Depends on what you are planning on machining as to whether the 25 is big enough. They're only a smallish hobby mill after all, good chip clearance from mist coolant helps and I added serious stiffening to the column to keep everything as rigid as possible. Its cuts better than I expected (coming from a Bridgeport).
Link here if any use
http://www.mycncuk.com/threads/10504...ng-an-AMAT25LVLast edited by Lloyd Barnes; 25-04-2017 at 09:30 PM.
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: Build Log: 3-4 Axis Mill/Router
By IanS1 in forum DIY Router Build LogsReplies: 35Last Post: 24-10-2014, 02:12 PM -
convert traditional machine or build router?
By Henrik in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-03-2013, 08:49 AM -
how to convert a mill to cnc?
By speedhound in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 10-11-2010, 09:07 PM -
RFQ: Convert/update my Triac cnc mill
By sopysnipe01 in forum Projects, Jobs & RequestsReplies: 0Last Post: 09-04-2010, 12:31 PM
