    Or it could be the stepper/ servo drive is not connected properly to board. STEP signal could be Rising edge or ??? Lowering edge / what was the exact name?/ edge, which if not right, each movement you will loose 1 step. Which if running large toolpaths you could not even see it, but run short multiple tool paths and all goes out of place. BUt as others said make sure its not the pulley slipping
    The way I read it, is that he is using 1 stepper with a belt connecting 4 screws and the screws are going out of sync.
    I think he is using the 4 screws to just lower or higher his bed. (one at each corner)
    If that is the case the rising edge thing is nothing to do with it.
    ok. you are right. i misread what he said. then very simple,all screws are not perfectly square maybe? each screw lowers a bit differently, assuming he has all connected with one belt.
    Kev, why dont you show us what exactly you are dong?
    hi sorry for late reply photos to show,
    there is 4 rods and nuts, table taken off to try too get it to work, photo shows rods and belt, and the 2 that im trying is out of sink,
    thank you guys for trying to help kev
Name:	my cnc 1.jpg
ID:	20872   Click image for larger version.
Name:	my cnc 2.jpg
ID:	20873   Click image for larger version.
Name:	my cnc 3.jpg
    When you set this up did you start with all the nuts at the top before you put the belt on? or loosen the grub screw on the pulley and then turn the screw to the correct position and then retighen
    hi clive yes done it where I could turn the belts and pulleys before tighten grub screws, put nuts top bottom and middle with a gauge block,
    These are things i do with Locktite, and i mean not the instant glue from grocery shop
    guys not sure if this is a stupid thing to think, but looking at all the nuts none off the plastic ball carrier matches each other, some are at bottom some are 6to7mm up, so could this effect what im trying, thanks again kev
  1. FOR SALE: For sale - 1605 ball screws & nuts. new unused
    By Stressedwoodman in forum Items For Sale
    Last Post: 29-09-2016, 07:19 PM
  2. 1605/1610 have they sent the wrong ones?
    By kingcreaky in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2013, 09:22 PM
  3. 1605 ballnuts
    By dudz in forum Lead Screws, Nuts & Supports
    Last Post: 30-03-2013, 09:31 AM
  4. FOR SALE: THK 1605 Balll screw and Nut
    By michael in forum Items For Sale
    Last Post: 28-07-2011, 08:34 PM
