    Lives in East Lothian, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    When you're there, try and work out a wiring diagram, and get some photos of how things are connected.
    If you can work out the activation signals to the VFD, see if they remain active when the spindle stops. There is the possibility that the controller is stopping the spindle when too high a speed is commanded, so knowing what the activation signal/speed set signal are doing narrows down to if it's a controller issue, or a VFD issue.
    10,000 revs divided by 50 hz equals 200.
    First check on the plate that the VFD can actually go to 400 hz, many can't. I have a couple here than can only go to 150 Hz and 200 Hz.
    Then check inside the parameters for Max Hz isn't set to 200 instead of 400.
    John S -
    cheers many thanks will have a look for all this tomorrow and report back fingers crossed its not to complicated and can be sorted as I want to cut some corian.
    OK. So I'm sure it is machine side of things as I does it without any file loaded. Trying to find a manual is proving hard but I found one for sale saying it does 400 hz just not sure if its set to that.
ID:	20911   Click image for larger version.
ID:	20912   Click image for larger version.
    Quote Originally Posted by charlieuk View Post
    Just don't change any parameters without knowing what you are changing. If you start experimenting without manual and just guess you may fry the VFD or the motor. Perhaps Mactec54 can maybe help you over on CNCZone.
    Find a seller that sells it on aliexpress or ebay, contact him and ask him for the manual. That simple.
    Where did you buy that spindle from?
    Or download a typical Chinese spindle manual, al is same same, with small differences. Find there the max frequency and max it to 400hz.
    here is the manual in Russian https://docviewer.yandex.com/?url=ya...c=58b415ee5c3b , lame but you can use copy past in google translator and get the important stuff
    from there:
    List of parameters 5.2 function
    Function number Setting range Value Function Description Default Comments
    P-000 Frequency setting mode selection
    0. Control panel ▲, ▼ to set;
    1. Panel Potentiometer
    2. Potentiometer FV terminal or setting 0-10;
    3. FI terminal installation of 4-20 mA signal;
    4. Control Panel ▲, ▼ set, if it is detected from the terminal to the FV potentiometer or 0-10V
    The signal will automatically switch to 5;
    5. Potentiometer terminal FV or setting 0-10, if detected panel ▲, ▼ work
    Automatic switching to 4;
    4 √
    P-001 Running command selection
    0. Control panel (Forward rotation start, reverse start, stop);
    1. Control Terminal (forward / stop and reverse / stop);
    2. Control Terminal (start / stop, forward / backward);
    3. Control Terminal (forward rotation start, reverse start, stop (NC));
    4. Other methods that automatically adapt;
    5. Control Terminal (forward rotation start, reverse start, stop (normally open));
    4 ╳
    P-002 Stop Mode
    0 Deceleration stop;
    1. Free stop;
    2. DC brake immediately;
    0 √
    P-003 prohibits the reversal of the engine
    0. This allows the engine to the contrary;
    1. Disable the motor reversal;
    0 √
    P-004 keyboard to prohibit the reverse rotation start
    0 Enable reverse keyboard start;
    1. Prohibition of the keyboard reverse start;
    1 √
    P-005 Start frequency 0.0-highest operating frequency of 1.0 Hz √
    P-006 Start delay 0.0-60.0 seconds to 0.0 seconds ╳
    P-007 Reserved
    P-008 automatic voltage sensitivity of 0 (lowest) to control 3 (high) 1 √
    P-009 Slip compensation 0.0-5.0Hz 0.0Hz √
    R-010 carrier frequency of 1000 Hz-12000Hz. When the carrier 999 by using a set of △ ╳
    The frequency of P-011 achieves a set 0.0-2000.0Hz 0.0Hz √
    Selection of P-012 analog output
    0 Analog frequency;
    1. Analog current device;
    2. The analog voltmeter;
    0 √
    Twenty three
    P-013 Analog Output Gain 50-200% 100 √
    P-014 Power Selection Show
    0. Frequency (H, F);
    1. Output current (A);
    2. The bus voltage (U);
    3. Approximate mechanical speed (r) = output frequency * P-015;
    4. PID set value (y);
    5. Inside the converter heatsink temperature (C);
    6. The output voltage (U);
    7. The counter value (J);
    8. Feedback PID (L);
    0 √
    R-015 speed factor 0.01-99.99 30.00 √
    User preferences Password P-016
    0. Do not set;
    Others, password settings, change the settings you must enter the value in the P-140;
    0
    P-017 0 memory frequency. No memory; 1. Memory; 2. memory before starting frequency; 1 √
    P-018 is the instantaneous power failure restart 0. Invalid; 1. Track your speed; 2. Restart; 0 √
    P-019 just restarted after a crash 0-10 times 0 √
    P-020, and then start waiting time of 0-60 seconds, 10 seconds √
    P-021 braking initial voltage
    220 Inverter: 350-400V 360V √
    380 Inverter: 650-700V 660V √
    P-022 anti-overvoltage during deceleration response point
    220 Inverter: 350-450V 400V √
    380 Inverter: 650-750V 700V √
    P-023 anti-accelerate in response to the points 110-150% over the nominal current of the inverter 130 √
    P-024 anti-overcurrent response at constant speed at 110-150% of the rated inverter current 150 √
    P-025 drive rated current ◎ △
    P-026 motor rated current 20-120% of the nominal drive current 100 √
    P-027 motor rated voltage
    Model 220: 50-450V 220 ╳
    Model 380V: 50-450V 380V ╳
    P-028 Rated motor frequency intermediate frequency of 50.0 Hz -2000.0Hz ╳
    P-029 intermediate voltage Minimum voltage -99% when the intermediate voltage is equal to the minimum voltage using torque boost 0 ╳
    P-030 intermediate frequency 1.0 Rated frequency 12.5 Hz ╳
    P-031 low voltage 0- intermediate voltage using torque boost 0 ╳, when the intermediate voltage is equal to the minimum voltage
    When P-032 0-30 torque increase (due to different types of aircraft), the intermediate voltage is less than or equal to a minimum effective voltage △ √
    P-033 the maximum operating frequency of the lowest operating frequency -2000.0Hz 60.0Hz √
    P-034 low operating frequency of 0.0 Hz is the maximum operating frequency of 0.0 Hz ╳
    P-035
    High frequency (PID maximum
    Setpoint) corresponding analog
    To come in
    0-100% 96 √
    P-036
    Low frequency (PID minimum
    To come in
    0-100% 2 √
    P-037 Reserved
    P-038 frequency upper limit frequency -2000.0Hz 60.0Hz ╳
    P-039 0.0-frequency limit the upper limit frequency of 1.0 Hz √
    Twenty four
    P-040 braking time 0.0-25.0 seconds 0.0 seconds √
    P-041 DC braking torque 0-30 (due to different aircraft types) △ √
    P-042 brake starting frequency Hz 0.0 -25.0 3.0 Hz √
    The regulator R-043 Rotary
    0. prohibited keyboard operation jogging
    1. Allow the keyboard turning operation
    1 √
    P-044 Rotary frequency low operating frequency - maximum operating frequency of 5.0 Hz √
    P-045 Acceleration Jog 0.05-650.00 seconds △ √
    P-046 cooks
    There's photos of the manual at -
    https://get.google.com/albumarchive/...slEh1HftK6nvSV
    Looks like X1-4 are used, however there doesn't appear to be anything that controls the speed. The ribbon cable goes to the remote display, and X terminals are basic inputs. You'll need to go through the menu, and find out what the X terminals are configured to do.
    Probably worth testing with a multimeter, and see if any of the X input statuses change above 10'000rpm.
  1. GRBL milling stopping randomly
    By Datulab in forum General Electronics
    Last Post: 15-01-2017, 08:52 PM
  2. Stepper motors keep starting and stopping
    By Davo242 in forum Stepper & Servo Motors
    Last Post: 03-01-2016, 02:27 PM
  3. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  4. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  5. Replies: 6
    Last Post: 27-05-2012, 06:06 AM
