Thread: Spindle stopping at 10,000 rpm?
There's photos of the manual at -
https://get.google.com/albumarchive/...slEh1HftK6nvSV
Looks like X1-4 are used, however there doesn't appear to be anything that controls the speed. The ribbon cable goes to the remote display, and X terminals are basic inputs. You'll need to go through the menu, and find out what the X terminals are configured to do.
Probably worth testing with a multimeter, and see if any of the X input statuses change above 10'000rpm.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
28-02-2017 #2
cheers many thanks for that I will go through it now!
28-02-2017 #3
28-02-2017 #4
I looked at the settings and they do appear different, I was just waiting for a reply to if I should change them. Not knowing to much I want to double cheque before I blow anything up! I put a tacho on it today and at 10000 it was only reading 9000
28-02-2017 #5
Mactec54 has a huge collection of manuals, if you ask him nicely maybe he will direct you to a pdf file or mail one to you. If there is a manual for "your" VFD, then you are safe, otherwise you are in the dark... and the options are: take a chance or use it as it is. I would take a chance if it was mine, after all, what is the worst that can happen? The VFD or the motor, or both gets fried. Not the whole world, and in that case at least I'd know.
GRBL milling stopping randomly
By Datulab in forum General ElectronicsReplies: 4Last Post: 15-01-2017, 08:52 PM -
Stepper motors keep starting and stopping
By Davo242 in forum Stepper & Servo MotorsReplies: 30Last Post: 03-01-2016, 02:27 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Dolphin Partmaster - what's stopping me from buying a license abroad?
By m_c in forum DolphinReplies: 6Last Post: 27-05-2012, 06:06 AM
