Thread: Cambam with Mach3
Here it is
Here are both files
ThanksLast edited by ladybreaker; 25-02-2017 at 05:31 PM.
25-02-2017 #3
25-02-2017 #4
I Clice
As I tryed to explain in the first post, when I Load G code to Mach3 the display shows only the circle on top of the profile and the rest of the cutout sre not visible,actualy they are not there at all. I tryed to run it on a piece of plywood and it only cut the circle !!
25-02-2017 #5
25-02-2017 #6
The tool is 2mm cutter ,some slots which are 3mm wide but the rest are more than 10mm
25-02-2017 #7
Ok if nobody answers I will load your gcode into Mach3 in the morning and see what it does.
edit: I have loaded it in CamBam and you appear to have a cut width peram set to 3 but you are using a profile tool path. I am not familiar with CB so not sure if that is correct.
Can you set this to auto and test again.Last edited by Clive S; 25-02-2017 at 08:47 PM.
25-02-2017 #8
I've just loaded the .nc file into Mach3 and the toolpaths all show up.
Setting rapids in CamBam
By swisscheese in forum CAD & CAM SoftwareReplies: 4Last Post: 04-04-2014, 02:30 PM -
Hobby-CNC Workflow - SKETCHUP + CAMBAM + MACH3
By WandrinAndy in forum Computer SoftwareReplies: 23Last Post: 04-10-2013, 02:53 PM -
Mach3 / cambam
By dudz in forum Artsoft Mach (3 & 4)Replies: 5Last Post: 01-04-2013, 06:02 PM -
Cambam / milling Alu
By dudz in forum CAD & CAM SoftwareReplies: 5Last Post: 23-12-2012, 05:22 PM -
How do i make this in cambam?
By motoxy in forum CAD & CAM SoftwareReplies: 4Last Post: 09-02-2012, 06:01 PM
