    The tool is 2mm cutter ,some slots which are 3mm wide but the rest are more than 10mm
    Quote Originally Posted by ladybreaker View Post
    Ok if nobody answers I will load your gcode into Mach3 in the morning and see what it does.
    edit: I have loaded it in CamBam and you appear to have a cut width peram set to 3 but you are using a profile tool path. I am not familiar with CB so not sure if that is correct.
    Can you set this to auto and test again.
    Lives in Plymouth, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    I've just loaded the .nc file into Mach3 and the toolpaths all show up.
    Thanks Neale saves me a job. Out of ideas then.
    Fred's Avatar
    Lives in Reigate, Albania. Last Activity: 24-04-2018 Has been a member for 9-10 years. Has a total post count of 34. Received thanks 4 times, giving thanks to others 1 times.
    Same here. All toolpaths look OK in CamBam and Mach3. I'd suggest is that you set your target depth to -3 rather than 3. but CamBam corrects this anyway. About to make a comment about the cut width then realized Clive has already done so.
    Quote Originally Posted by Fred View Post
    Yes the Gcode shows -3mm so no prob there. Not sure about the width peram set to 3 with a 2mm cutter and a profile pass!!
    Something is wrong with your mach3 not the g-code. I have the mach3 demo installed for testing purposes without any settings altered. Your g-code shows up and runs perfectly.
  1. Setting rapids in CamBam
    By swisscheese in forum CAD & CAM Software
    Last Post: 04-04-2014, 02:30 PM
  2. Hobby-CNC Workflow - SKETCHUP + CAMBAM + MACH3
    By WandrinAndy in forum Computer Software
    Last Post: 04-10-2013, 02:53 PM
  3. Mach3 / cambam
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 01-04-2013, 06:02 PM
  4. Cambam / milling Alu
    By dudz in forum CAD & CAM Software
    Last Post: 23-12-2012, 05:22 PM
  5. How do i make this in cambam?
    By motoxy in forum CAD & CAM Software
    Last Post: 09-02-2012, 06:01 PM
