Thread: Where Do The Wires Go ?
That BOB looks like the zp5a-int. Quick Google search will turn up a manual for it and you might be able to find some sample connection diagrams. Each axis has three signal outputs (pulse, dir, enable) and ground. I can't remember if it can sink current or just source it but those driver connections sound as if they need the BOB to sink current (open collector output). I think I used mine to source current into driver opto-isolator inputs. I was using this with M752 (big brother of driver mentioned in link given above) but driver described by OP sounds as if its input connections are rather different.
25-02-2017 #2
by the sounds of it the driver has a common anode where the VCC (5V) is powering the opto and it is stepping when the pulse and pulled to gnd. (NPN)
the breakout board outputs a 5V to step. (PNP)
I think that gives you the answer to your question.Last edited by Gary; 25-02-2017 at 08:42 AM.
Visit Us: www.automationshop.co.uk
25-02-2017 #3
voltage on motor wires
By phill05 in forum General ElectronicsReplies: 9Last Post: 11-02-2012, 03:43 PM
