    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Quote Originally Posted by neilricketts View Post
    I have tried the active low in mach 3 which just causes the z axis to go in opposite direction. For example press up it goes down, press down it goes up.
    I should have mentioned that you have to find another way to reverse the axis direction. Simplest way is to change the "Direction" signal from active-high to active-low (or vice versa) when you change the step polarity.
    hi my stepper drivers are these http://www.ebay.co.uk/itm/CNC-Single...EAAOSwnH1WXWIT the two led clearly state pwr/alrm
    Cheers Neil
    I've literally these last 10 minutes just come in from the shed from dismantling two of these which were not working correctly (new design, first time I've tried these). From the outset, though they are called TB6600 - they certainly don't have a Toshiba TB6600 on board - instead, some surface mount QFP device with a splodge of heat-sink compound with a best-hope bonding to the heatsink. Also, the alarm alternates for every received clock signal - it's not a fault, but it's a poo design.
    I actually came to this site on the offchance someone was selling some drivers, failing that I'm online to get something a bit more respectable.
    hi doddy i am glad someone else is having the alarm light flickering on and off. I am in the market for some better drivers at a reasonable price. I am considering these if i can find someone who has used them.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...e&talgo=origal
    http://www.ebay.co.uk/itm/2625479434...%3AMEBIDX%3AIT
    Would you let me know what you decide to go with.
    Cheers Neil
  5. #15
    Doddy As you know its hard to beat the AM882 drives
  6. #16
    ...or to find them in the UK.
    Gnngh!, I've spent the last week and then some crafting two folded steel sleds (one power, one control) that fit in the mount-frame of a Starmill... now anything larger than the original drivers isn't going to fit and I'm back to the start, making a tray to take all the gubbins.
    Time to go find a cat to kick.
  7. #17
    Hi does anyone know of good supplier of shielded 2 or 4 core cable.
    Cheers Neil
  8. #18
    Cheers Neil
    Search for 1mm or 0.75mm cy4 cable like https://quickbit.co.uk/Cable/CY-Cabl...-0-75mm-4-core or https://www.cse-distributors.co.uk/a...Y_4C_0_75.html
    edit only connect the screen at one end to a star point
  9. #19
    hi clive s thankyou for the links i will order some first thing monday. Just wondering has anyone any experience with these stepper drivers
    http://www.ebay.co.uk/itm/CNC-Single...3D251425126351
    Cheers Neil
  10. #20
    Cheers Neil
    As I have said before you need to up the voltage on the power supply. I would do that first. Those drives you linked to are 50V drives so you should be able to run them at at 40V
  1. Please help - missing steps ... Mach3
    By emilvv in forum Artsoft Mach (3 & 4)
    Last Post: 23-12-2019, 08:31 AM
  2. How I solved MY missing steps problem.
    By davegrennan in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 08:27 PM
  3. New machine bogging down / missing steps
    By James123 in forum Gantry/Router Machines & Building
    Last Post: 19-12-2014, 12:02 AM
  4. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
