    hi clive s thankyou for the links i will order some first thing monday. Just wondering has anyone any experience with these stepper drivers
    http://www.ebay.co.uk/itm/CNC-Single...3D251425126351
    Cheers Neil
    Quote Originally Posted by neilricketts View Post
    Cheers Neil
    As I have said before you need to up the voltage on the power supply. I would do that first. Those drives you linked to are 50V drives so you should be able to run them at at 40V
    Hi, i know what you are saying but i am happy at 24v with the speed and that. it is just the missing steps that i think is being caused either through electrical noise which i will try changing the wiring first. However reading here and on other forum the tb6600 drivers are a common cause of lost steps and failing that is why i am asking about the other drivers as a possible replacement if i have to go down that route.
    Ok if you are happy so I won't mention it again but just let me say you will need all the power you can get using threaded rod. Turning the power up will help with lost steps.
    Lives in Plymouth, United Kingdom. Last Activity: 7 Hours Ago Has a total post count of 1,746. Received thanks 297 times, giving thanks to others 11 times.
    My mk1 router, built from MDF, used M10 threaded rod as leadscrews. I used M752 drivers running off 68V. Never had a missed step, as far as I could tell. Had a lot of other structural problems, mind you... That was a bit OTT but I intended to re-use the electronics in a later version.
    I'm still slightly unsure of the "missed step" assumption. Can you measure how much error there is after, say, 50 vigorous Z moves? 100 moves? Are the results consistent, or random? Change the speed and acceleration and try again? Before junking the drivers and replacing them with different cheap low-power drivers, it might be useful to get a better handle on the underlying problem. I might even swap a couple of drivers between axes and see if the problem follows the driver. Reroute the wires and see if anything changes. A bit of science is called for, carefully measuring and only changing one thing at a time, despite your obvious frustration! I found my Z problem when I was able to see that the error in microsteps after each height-setting operation was almost always equal to the number of direction changes during height setting, for example, and the error was independent of how far the axis travelled.
    Hi Clive S thankyou and I do appreciate your advice its just I know of cnc machines running on 24v and m10 threaded bars with no missing steps. I will consider changing and increasing the psu voltage if necessary I want to explore all avenues. The machines I know of that run on 24v don't use the tb6600 drivers but they use gecko ones which at the moment are out of my price range as I am just a hobbiest. I will however keep your advice on hand increase that is the route I decide to go.
    Cheers Neil
    Hi, Neale the missing steps on the z axis is after doing a v carving of a Harley Davidson eagle plaque for example the bit will have raised above the work piece by anything from 1mm to 3.6mm. It is not consistent. I have tried switching drivers from other axis. Changing stepper motors from other axis. I have also changed from 1/8 step to 1/4 stepping, I have tried lowering and raising the amperage settings on the driver. I have also tried slowing the ipm to just 5 with acceleration to 5 and it still raises up from the work piece. I have made numerous different anti backlash nuts and my current design is spring loaded. The only thing that I notice is the alarm led is constantly flickering on and off on the driver when it is changing direction. However all the drivers do this on all of the axis and I do lose steps on my axis just not as much as the axis which is the hard working one.
    If I do just normal cutting for example 2d cuts I don't have a problem only when there is a lot of up down movements. At first I thought I may have been my nut but not so sure now.
    cheers neil
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    Do the axes always drift in the same direction?
    If so, my first suggestions would be to try inverting the direction and/or step active high/low.
    When the direction changes, the driver requires that the direction signal is changed at a certain point before the step signal. If it doesn't, the driver can move one step pulse in the wrong direction before changing to the correct direction. Over the course of many moves, this can lead to axis drift in a constant direction.
    One possible test for noise problems, is too only move 2 axes, with the other remaining stationary (ideally against a DTI, or mark the coupler so you can see movement easier), and see if the stationary axis moves any. Also try with the spindle running, as they can also produce noise which can cause phantom steps.
  1. Please help - missing steps ... Mach3
    By emilvv in forum Artsoft Mach (3 & 4)
    Last Post: 23-12-2019, 08:31 AM
  2. How I solved MY missing steps problem.
    By davegrennan in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 08:27 PM
  3. New machine bogging down / missing steps
    By James123 in forum Gantry/Router Machines & Building
    Last Post: 19-12-2014, 12:02 AM
  4. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
