14-08-2009 #13
Ok, I'm on the home straight ...I just need a sanity check re the DC motor connections & the 'current sense' resistor.
Firstly, I reckon the DC motor connections are A1 & A2 on this diagram (there are spade connectors marked as such on the PCB)...
(John S, confirmed that on the original Sieg board that A1 & A2 are the DC Motor connections & I gather this must be a standard naming convention, but those F1 & F2 connectors are messing with my head!)
Ok, next challenge' ....current sense resistor! This board talks of having an external current sense resistor, but if you look at the chart, it seems ludicrously low...
my motor is 250W, which apparently is 1/3rd of a horsepower - therefore looking at that chart it needs a current sense resistor that is 0.027 Ohms - are they having a laugh?
Where on earth will I be able to source a resistor such as that? (Danfoss apparently don't make these driver boards any more ...not sure if Graham do) ...since the resistor is in series with the motor ...it's going to have to be able to handle a fair whack of current...therefore I'm figuring it'll need to be able to disappate a fair bit of power too?
Has anyone experience of such current sense resistors? Is there a 'frig' where I can do away with the darned thing?
Many thanksLast edited by HankMcSpank; 14-08-2009 at 03:49 PM.
VFD to USB WIRING ????
By Stucncusb in forum Spindles & Drive MotorsReplies: 0Last Post: 23-08-2013, 07:06 PM -
Chester MF42B Lathe Wiring Issues
By kingcreaky in forum General ElectronicsReplies: 5Last Post: 18-02-2013, 02:21 PM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM -
wiring help
By deannos in forum Motor Drivers & ControllersReplies: 3Last Post: 08-06-2011, 02:20 PM -
Wiring diagram for boxford cnc lathe 125TCL?
By Sampop in forum Boxford LathesReplies: 0Last Post: 28-10-2010, 05:20 AM
